[PROJ] Grid CDN Update and Crowdfunding Request
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Thu Nov 14 00:22:05 PST 2019
A repository would be nice and a new grid format is welcome too. I do not like NTv2 due to its peculiarities:
Correction values, metadata on spacing and even grid bounds are given in arcseconds instead of decimal degrees. Longitude values have inverted sign, thus east of the Greenwich meridian is negative. This affects the correction values and the metadata values for the grid bounds. Also the order in which the correction values are given in the NTv2 correction grid file, is from southeast to northwest and starts with the east-west direction. While the order in which the correction values are listed in the VDatum grid file is better: from southwest to northeast and starts with the west-east direction.
Kind regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191114/d81d4ace/attachment.html>
More information about the PROJ mailing list
