[PROJ] How to construct proper cs2cs command line arguments
Kristian Evers kreve at sdfe.dk
Mon Nov 25 04:22:59 PST 2019
Jean Louis,
Take a look at the documentation for cs2cs. I believe it should answer all your questions regarding cs2cs.
Here it is: https://proj.org/apps/cs2cs.html
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Jean Louis
Sent: 25. november 2019 13:15
To: proj at lists.osgeo.org
Subject: [PROJ] How to construct proper cs2cs command line arguments
Hello,
I have been using this: https://mygeodata.cloud/cs2cs/
and I used input:
+proj=longlat +datum=WGS84 +no_defs
or EPSG:4326
and output to be:
+proj=utm +zone=36 +ellps=clrk80 +towgs84=-160,-6,-302,0,0,0,0 +units=m +no_defs
or Arc 1960 / UTM zone 36N (EPSG:21096)
then with coordinates:
-1.122159, 29.714413
I could get 134183.400916;-123935.185151
which looks proper to me.
But how exactly do I construct the cs2cs command line?
Jean
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
