[PROJ] Management of datum grid files.
Kristian Evers kreve at sdfe.dk
Wed Nov 27 00:14:27 PST 2019
Perhaps we should look into using %APPDATA%\Local\PROJ as the default path
for %PROJ_LIB% on Windows?
This has been good practice on Windows for quite a while now. I guess the reason
that PROJ doesn't have a default location on Windows is that in earlier versions of
Windows no such place was available.
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: 26. november 2019 23:12
To: proj at lists.osgeo.org
Subject: Re: [PROJ] Management of datum grid files.
> No. The PROJ binary has no idea where PROJ_LIB can be pointed too. That's
> why it is needed to be defined. For some builds typically done by Linux
> distributions where the installaton path is known at build time, the
> default search path is hardcoded in the binary, but for Windows, the actual
> installation path is rarely known in advance.
Yes, that's why I floated around the idea that PROJ default search path could
also include the  ${XDG_DATA_HOME}/proj directory, where ${XDG_DATA_HOME}
resolves to ${HOME}/.local/share on Unix builds and ${USERPROFILE}/.local/
share on Windows builds, that RFC4 plans to use to put the local cache of
downloaded chunks from the CDN. That has also the advantage that it is a user
writable directory, which can help people not having admin rights.
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
