[PROJ] Management of datum grid files.
Chris Crook ccrook at linz.govt.nz
Wed Nov 27 13:02:32 PST 2019
I'm not sure it makes sense to look in the current directory by default.  It seems to me this could inadvertently pick up a grid file that was not deliberately installed into the system.  Would it be safer to require that local grids are explicitly requested, eg ./grid_file
Cheers
Chris
> -----Original Message-----
> From: PROJ [mailto:proj-bounces at lists.osgeo.org] On Behalf Of Kristian
> Evers
> Sent: Thursday, 28 November 2019 9:40 a.m.
> To: Helmut Kudrnovsky
> Cc: proj at lists.osgeo.org
> Subject: Re: [PROJ] Management of datum grid files.
> > On 27 Nov 2019, at 21:31, Helmut Kudrnovsky <hellik at web.de> wrote:
> >>> Keep in mind, in the most cases in windows,  proj  is bundled with
> >>> other Software.
> >>> E.g. OSGeo4W where proj needed files are living in  e.g.
> >>> c:\OSGeo4W\share\proj\ or in standalone winGRASS or qgis where  proj
> >>> needed files are living in e.g. c:\programs\qgis\share-subfolder
> >>> and %PROJ_LIB% is set accordingly.
> >> That's one of the reason to propose an installation-independent
> directory.
> >> That way different installations may be able to use the same grids &
> cache.
> > so the idea is:
> > that e.g. OSGeo4W puts the proj shared things into %LOCALAPPDATA%, a
> > standalone GIS software depending on proj looks into %LOCALAPPDATA%
> if
> > there is a subfolder called e.g. proj? or the other way around, a
> > standalone GIS software depending on proj puts needed files into
> > %LOCALAPPDATA%\proj and OSGeo4W looks while updating/upgrading its
> > proj version into %LOCALAPPDATA% if there is a proj subfolder with
> > shared folders? what if in %LOCALAPPDATA%\proj are already files with
> > the same name? should these be just overwritten? how will be there a
> > track of updated/ugraded/changed shared proj files if different
> > software are working/updating/upgrading them at the same time?
> > or should be set %PROJ_LIB% windows system wide (for all users? for
> > just one user in a multiuser network?) and a standalone GIS software
> > depending on proj/OSGeo4W while updating looks for %PROJ_LIB%
> instead
> > of %LOCALAPPDATA%\proj?
> > will this work in the windows side of the world? ;-)
> > I'm not against a consolidated way how to deal with proj supporting
> > files like grids and their big file sizes; with a _co-maintainer of
> > winGRASS_ hat on, I know, windows can be sometimes a hardly
> manageable
> > beast ... here just for well thought solution on the windows side of
> > the world ;-)
> I would think that we would mostly just continue doing what we doing with
> PROJ_LIB at the moment with the addition of looking for usable grids in
> %APPDATA% (on Windows).
> This is somewhat equivalent to what is done on unix-based installs already,
> where the logic for finding grids is something like:
> 1. Look in current dir
> 2. Look in search paths set by API function 3. Look in PROJ_LIB 4. Look in
> /usr/local/share/proj or whatever was specified with ./configure
> On Windows step 4 would look for resources in %APPDATA%\PROJ
> Is that a reasonable approach?
> /Kristian
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the PROJ mailing list
