[PROJ] Way to transform coordinates given an osgeo::proj::operation::CoordinateOperation?
    Martin Desruisseaux
    martin.desruisseaux at geomatys.com
    Wed Oct  9 06:47:26 PDT 2019
Hello
I'm trying to find the best way to transform coordinate tupples given an
osgeo::proj::operation::CoordinateOperation instance. My current
understanding is that I need to get a PJ object as below. Is that correct?
    CoordinateOperationNNPtr operation = ...
    PJ_CONTEXT *ctx = ...
    PJ *pj = (ctx, operation);
    // Then use PJ as documented in "getting started" guide.
If above is the right approach, looking at the source code of
pj_obj_create, there is two things I would like to do differently:
  * Use an existing osgeo::proj::io::DatabaseContext instance.
  * Do not fallback on pj_new() if the main block could not create the PJ.
So would the following block be okay (I know if use an internal method
call, but I didn't saw a way to avoid it yet):
    DatabaseContext dbContext = ...;
    auto formatter = PROJStringFormatter::create(PROJStringFormatter::Convention::PROJ_5, dbContext);
    auto projString = coordop->exportToPROJString(formatter.get());
    PJ *pj = pj_create_internal(ctx, projString.c_str());
    // Done; do not touch to pj->iso_obj or pj->cpp_context.
Or is there a better way to "execute" a CoordinateOperation with C++ API?
     Thanks,
         Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191009/47d619eb/attachment.html>
More information about the PROJ
