[PROJ] Way to transform coordinates given an osgeo::proj::operation::CoordinateOperation?
Even Rouault even.rouault at spatialys.com
Wed Oct 9 08:28:44 PDT 2019
On mercredi 9 octobre 2019 17:07:52 CEST Martin Desruisseaux wrote:
> Le 09/10/2019 à 16:56, Even Rouault a écrit :
> > Or use
> > void PROJ_DLL proj_assign_context(PJ* pj, PJ_CONTEXT* ctx);
> Thanks! I didn't saw that one. It should do the trick for the
> multi-threading issue.
Was recently moved from proj_experimental.h to proj.h
http://www.spatialys.com
More information about the PROJ mailing list
