[PROJ] Documentation typo (minor)
Even Rouault even.rouault at spatialys.com
Sat Oct 12 06:56:07 PDT 2019
Martin,
Can you just use pull requests to optimize overall efficiency :-) ?
Even
On samedi 12 octobre 2019 15:37:47 CEST Martin Desruisseaux wrote:
> C++ API documentation for SingleCRS.coordinateSystem() [1] contains
> /"This might be null, in which case datumEnsemble() return will not be
> null"/. I think this is an accidental copy-and-paste from the
> SingleCRS.datum() documentation and that this sentence (together with
> /"that might be null"/ in the return description) should be removed in
> the coordinateSystem() case.
> [1]
> https://proj.org/development/reference/cpp/crs.html#_CPPv4N5osgeo4proj3crs9
> SingleCRS16coordinateSystemEv
>      Martin
http://www.spatialys.com
More information about the PROJ mailing list
