[PROJ] Test failure when building on Windows
Even Rouault even.rouault at spatialys.com
Tue Oct 22 13:29:18 PDT 2019
yes not sure what's wrong on your end, but PROJ AppVeyor continuous
integration builds use sqlite 3.30.1 from vcpkg and the tests pass fine.
Even
> Hello,
> I am working with proj 6.2.0 on Windows, have gotten it to build using
> Visual Studio 2017, and all tests pass except one when I run ctest.  It is
> the "factory.attachExtraDatabases_auxiliary" test in proj_test_cpp_api.
> The error message printed is:
> unknown file: error: C++ exception with description "geodeticCRS not found"
> thrown in the test body.
> I am building proj with the sqlite code from
> sqlite-amalgamation-3300100.zip, which is the latest version of sqlite as
> of today.
> The only way I have managed to get the test to pass is if I change line 2471
> of proj-6.2.0/test/unit/test_factory.cpp to remove the "mode=memory"
> setting.
> I'm at a loss how to troubleshoot this.  Is this a proj issue, a sqlite
> issue, or perhaps most likely, an issue with my build?  Any
> advice/suggestions would be much appreciated.
> Thanks!
> Asa
> Asa Packer  | Lead Systems Engineer
> BioSonics, Inc.
> 2356 W Commodore Way, Unit 110
> Seattle WA 98199-1258 USA
> tel 206.782.2211 |  biosonicsinc.com<http://www.biosonicsinc.com/>
http://www.spatialys.com
More information about the PROJ mailing list
