[PROJ] PROJ 6.2.1RC1
Alan Snow alansnow21 at gmail.com
Wed Oct 30 20:26:18 PDT 2019
All builds pass as expected with pyproj. Thanks!
On Mon, Oct 28, 2019 at 1:01 PM Kristian Evers <kristianevers at gmail.com>
wrote:
> All,
> With a scheduled release of PROJ 6.2.1. on November 1st it is time to put
> out a
> release candidate. This release is a bug fix release which contain more
> than
> twenty bugs fixes.
> Download the archives here:
> http://download.osgeo.org/proj/proj-6.2.1RC1.tar.gz (
> http://download.osgeo.org/proj/proj-6.2.1RC1.tar.gz.md5)
> http://download.osgeo.org/proj/proj-6.2.1RC1.zip    (
> http://download.osgeo.org/proj/proj-6.2.1RC1.zip.md5)
> See the release notes below.
> Please test the release candidates and report back any problems you
> may encounter.
> Providing that no problems with the release candidate is found, I will
> call for a PSC vote
> Wednesday morning with a plan to release Friday November 1st.
> /Kristian
>  Updates
>  o Update the EPSG database to version 9.8.2
>  Bug fixes
>  o Fixed erroneous spelling of "Potsdam" (#1573)
>  o Calculate y-coordinate correctly in bertin1953 in all cases (#1579)
>  o proj_create_crs_to_crs_from_pj(): make the PJ* arguments const PJ*
> (#1583)
>  o PROJStringParser::createFromPROJString(): avoid potential infinite
>    recursion (#1574)
>  o Avoid core dump when setting ctx==NULL in functions
>    proj_coordoperation_is_instantiable and
>    proj_coordoperation_has_ballpark_transformation (#1590)
>  o createOperations(): fix conversion from/to PROJ.4 CRS strings with
>    non-ISO-kosher options and +towgs84/+nadgrids (#1602)
>  o proj_trans_generic(): properly set coordinate time to HUGE_VAL when no
>    value is passed to the function (#1604)
>  o Fix support for +proj=ob_tran +o_proj=lonlat/latlong/latlon instead of
> only
>    only allowing +o_proj=longlat (#1601)
>  o Improve backwards compatibility of vertical transforms (#1613)
>  o Improve emulation of deprecated +init style initialization (#1614)
>  o cs2cs: autopromote CRS to 3D when there's a mix of 2D and 3D (#1563)
>  o Avoid divisions by zero in odd situations (#1620)
>  o Avoid compile error on Solaris (#1639)
>  o proj_create_crs_to_crs(): fix when there are only transformations with
>    ballpark steps (#1643)
>  o PROJ string CRS ingester: recognize more unit-less parameters, and
> general
>    handling of +key=string_value parameters (#1645)
>  o Only call pkg-config in configure when necessary (#1652)
>  o aeqd: for spherical forward path, go to higher precision ellipsoidal
>    case when the point coordinates are super close to the origin (#1654)
>  o proj_create_crs_to_crs(): remove elimination of Ballpark operations
>    that caused transformation failures in some cases (#1665)
>  o createOperations(): allow transforming from a compoundCRS of a bound
>    verticalCRS to a 2D CRS (#1667)
>  o Avoid segfaults in case of out-of-memory situations (#1679)
>  o createOperations(): fix double vertical unit conversion from CompoundCRS
>    to other CRS when the horizontal part of the projected CRS uses
> non-metre
>    unit (#1683)
>  o importFromWkt(): fix axis orientation for non-standard ESRI WKT (#1690)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Alan Snow
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191030/f48c0f50/attachment.html>
More information about the PROJ mailing list
