[PROJ] How to find the active metadata search path in PROJ 6
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Sep 8 00:28:59 PDT 2019
On 9/8/19 9:25 AM, Roger Bivand wrote:
> It does seem justified, doesn't it? It might be even more sensible if
> (at some time in the future) the user-writable cache directory was
> shared between applications, so that different R or Python packages or
> QGIS etc. didn't each have to have separate dumps of the same grid files
> ... just speculating.
$XDG_DATA_HOME/proj is appropriate for the user-writable cache.
Per:
 https://specifications.freedesktop.org/basedir-spec/basedir-spec-latest.html
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
