[PROJ] EXTERNAL: PROJ logo proposal
Wells, Roger K. ROGER.K.WELLS at leidos.com
Tue Sep 10 07:20:17 PDT 2019
1A for me
On 9/10/19 10:09 AM, Nicolas B. wrote:
Hi list,
Following a discussion with Kristian in late 2018 , i am glad to finally share a few logotypes for your consideration. I fully agree that PROJ needs a logo and that would be the perfect touch for upcoming incubation :)
https://nbozon.github.io/OSGeo/proj/PROJ_logo_proposal.pdf
This is a draft proposal at this stage, and i would be glad to work further on one particular logo that you may like, using the community feedbacks.
Please note:
- These are only logotypes. Logotexts can also be created, or the 'PROJ' word may be added to any of these (this involves we may select a particular open font).
- These are simple SVG shapes provided in black color for now
   (Colors can of course be proposed later on, if you like one of these)
- This work is licensed under CC BY-NC 4.0 at this stage, but i am happy to create new version using a more permissive license if needed.
- I have more SVG drafts based on the 'P' letter, as well as additional ideas using axis and coords elements, but i unfortunately can't shared them for now.
- I am sharing this document as PDF for the sake of simplicity, but i am happy to provide the source SVG at a later stage, along different formats so we could easily reuse it on website and OSGeo marketing material.
This is only a simple proposal and i hope you will like it.
I am looking for your feedbacks, and will be glad to use one of these in order to create the perfect logo, with colors and text.
Best regards,
Nick
PROJ mailing list
PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
Roger Wells, P.E.
leidos
221 Third St
Newport, RI 02840
401-847-4210 (voice)
401-849-1585 (fax)
roger.k.wells at leidos.com<mailto:roger.k.wells at leidos.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190910/0bd7ad4c/attachment.html>
More information about the PROJ mailing list
