[PROJ] PROJ grid files CDN
Even Rouault even.rouault at spatialys.com
Fri Sep 13 11:07:30 PDT 2019
> If the remote update feature will require extra build time configuration or
> environment configuration, how will these users benefit? If you don't know
> you're using PROJ, how do you know to enable this? Don't these users need
> it on by default?
Good point. I can imagine that an application with a GUI such as QGIS could
ask the question to the user "QGIS might download resource files needed for
coordinate transformation. Do you agree ?", and if they approve, set the
appropriate environment variable.
A realistic use case for this download-on-demand capaibility is that you know
that PROJ exists, that you are going to use it, but you don't know in advance
which part(s) of the world you're going to work on, and don't want to / cannot
download data for the whole world in advance.
> I think there are also security considerations. Is PROJ proofed against
> malicious grid files like our browsers are against malicious javascript?
In that context, one should indeed have a deeper look at how it opens them and
try to secure that (with the curent raw formats which are quite simple, that
shouldn't be too challenging). That said, the resources it would fetch would
not be random, so unless a hostile party manages to upload a corrupted file in
the CDN storage (or changes entries in the local proj.db), the set of what is
access should be rather well defined.
Note: those concerns about security are already valid currently. For example
if using a PROJ string with a geoidgrids/nadgrids parameter that points to a
local file that would be hostile.
> Somewhat off topic: should PROJ be returning incorrect results in the
> absence of grid files? Should it not raise an exception instead?
There's no such thing as a "correct result" regarding coordinate
transformation that involve changes of datum. There are results that are more
or less accurate given the possibilities offered in the database which are
themselves somewhat arbitrarily available according to what national geodetic
agencies have provided to EPSG, which tranformation methods are actually
implemented in PROJ, etc. So depending on what is available and what your
needs are, you could get a result that is correct with an accuracy of 100m,
10m, 1m, 1cm...
In reality, the difference of accuracy between using a 7-parameter Helmert
transformation vs using a grid is quite often 1m vs 10cm, so raising an
exception when the grid is not there could be over-zealous if the user hasn't
required a particular level of acuracy and the result given by the 7-parameter
Helmert is just fine for them.
The lower level services of PROJ can give you the available possibilities,
with their accuracy and if some resources are missing or not, and where they
can be downloaded.
http://www.spatialys.com
More information about the PROJ mailing list
