[PROJ] A few PROJ Logo propositions
jmfluis at gmail.com jmfluis at gmail.com
Sat Sep 21 08:39:49 PDT 2019
I like 7C better. It has the advantage of the aspect ratio (almost square).
Joaquim
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Christina Chortaria
Sent: Tuesday, September 17, 2019 8:20 PM
To: sylvain.beorchia at gmail.com
Cc: proj at lists.osgeo.org
Subject: Re: [PROJ] A few PROJ Logo propositions
Sylvain,
Thank you for taking the time to create these logos! My preference would be 9A and 9B (on a green plane).
Thank you again,
Christina
On Tue, Sep 17, 2019 at 3:04 PM Sylvain Beorchia <sylvain.beorchia at gmail.com <mailto:sylvain.beorchia at gmail.com> > wrote:
Thanks Thomas for your feebacks.
Here are a few new tries (work in progress) : http://dakitanmonkey.2tokiislands.com/proj_logos_4.png (lines 10 and 11), inspired by your suggestions.
Sylvain.
Le mar. 17 sept. 2019 à 07:48, Thomas Knudsen <knudsen.thomas at gmail.com <mailto:knudsen.thomas at gmail.com> > a écrit :
I am unconvinced (or actually rather strictly against) the “globe and plane” style logo candidates: They focus too narrowly on the projection side of things, which is already indicated quite clearly through the name PROJ.
I kind of like 3C, with the phi and its shadow - the shadow somehow indicating a “related but not identical reference frame”, i.e. a datum shift.
I do, however, not like the shape of the phi (or actually “varphi”: phi is the “O with bar strikethrough” often used to indicate a clock phase): The very open-to-the-left varphi looks too much like the word “up”.
I would like the logo to indicate more clearly that geodesy is a four-dimensional science, and the operations PROJ provide support that.
So perhaps something like 3C, but with the letters “P R O J” casting the shadows “varphi lambda H t” - or for the sake of simplicity and recognizability in small sizes: Just the four letters “varphi lambda H t” on one line, and “P R O J” below that:
φλHt
(where the phi was supposed to be a varphi)
It may be a challenge to make it work graphically, since varphi descends, and lambda, H and t ascends - but I am sure this can be made to work by someone more graphically skilled than myself.
/thomas
Den man. 16. sep. 2019 kl. 16.27 skrev Sylvain Beorchia <sylvain.beorchia at gmail.com <mailto:sylvain.beorchia at gmail.com> >:
Thanks for the feedback  and suggestions.
Let's wait some more reactions of the community for my propositions, and also for the other's (Nicolas, Janne...) one.
Le lun. 16 sept. 2019 à 15:55, Kristian Evers <kreve at sdfe.dk <mailto:kreve at sdfe.dk> > a écrit :
Thank you! I’ve come to the conclusion that of your proposals I like 5B the best. I like the wire-frame globe and that the plane below it is sort of the projected footprint of the globe. Additionally I like that the colors are simple (no shades and gradients) which I believe is more suitable for a logo. Additionally the red can be replaced with other colors depending on the context, for instance the OSGeo website which uses a black and green colorscheme.
/Kristian
From: Sylvain Beorchia <sylvain.beorchia at gmail.com <mailto:sylvain.beorchia at gmail.com> >
Sent: 16. september 2019 13:55
To: Kristian Evers <kreve at sdfe.dk <mailto:kreve at sdfe.dk> >
Cc: Even Rouault <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com> >; proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>
Kristian,
I've added a new version there http://dakitanmonkey.2tokiislands.com/proj_logos_3.png including your suggestion (9B)
Le lun. 16 sept. 2019 à 09:51, Kristian Evers <kreve at sdfe.dk <mailto:kreve at sdfe.dk> > a écrit :
Thanks Sylvain,
These are indeed some good logo proposals. Like Even I also like the 2B/9A logo. I also like the 5B version. It would be interesting to see a combination of 5B and 9A. I like the wireframe globe and the red from 5B.
/Kristian
From: PROJ <proj-bounces at lists.osgeo.org <mailto:proj-bounces at lists.osgeo.org> > On Behalf Of Sylvain Beorchia
Sent: 14. september 2019 00:08
To: Even Rouault <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com> >
Cc: proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>
Sorry bad link,
http://dakitanmonkey.2tokiislands.com/proj_logos_2.png
Le sam. 14 sept. 2019 à 00:07, Sylvain Beorchia <sylvain.beorchia at gmail.com <mailto:sylvain.beorchia at gmail.com> > a écrit :
Even,
I added your suggestion to the list (A9)
http://dakitanmonkey.2tokiislands.com/proj_logos_2.png <http://dakitanmonkey.2tokiislands.com/proj_logos.png>
Le ven. 13 sept. 2019 à 23:49, Even Rouault <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com> > a écrit :
On vendredi 13 septembre 2019 23:26:48 CEST Sylvain Beorchia wrote:
> Hi,
> Here are some few propositions for the PROJ logo :
Thanks Sylvain. My preference would go to 2B, but perhaps with a uppercase J.
Wondering if it wouldn't be better to enlarge a bit the green plane so that
all letters (especially the P) are on it ?
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190921/79cff205/attachment.html>
More information about the PROJ mailing list
