[PROJ] build failure with GCC 9.1.0
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Wed Sep 25 00:54:46 PDT 2019
Le 24/09/2019 à 15:37, Even Rouault a écrit :
> Hi
>> Could it comes from my buildbox (Solaris 11.4.12) ?
> Definitely a Solaris specific thing.
> Should hopefully be fixed by https://github.com/OSGeo/PROJ/pull/1637
> Can you confirm this patch fixes the issue ?
I am afraid it is not enough. Please find attached 4 additional patches :
     - proj-6.2.0-hanato.gpatch and proj-6.2.0-mbtfpp.gpatch
In files src/projections/hatano.cpp and src/projections/mbtfpp.cpp,
change the CS define to CSz in order to avoid overriding the CS system
definition
     - proj-6.2.0-isea.gpatch :
In file src/projections/isea.cpp, change the quad variable name as it is
overriding another system definition
$ grep quad  /usr/include/sys/types.h
typedef struct _quad { int val[2]; } quad_t;    /* used by UFS */
typedef quad_t          quad;                   /* used by UFS */
     - proj-6.2.0-io.gpatch
In file src/iso19111/io.cpp, change another class name that override the
CS system define
$ gegrep '[[:space:]]CS[[:space:]]' /usr/include/sys/regset.h
#define CS              15
With those changes, 6.2.0 build and check properly on Solaris 11.4.12
and GCC 9.1.
Note : I quite understood what I changed in the first 3 patches. Not
sure in the last one. Can you please review it ?
Regards.
Eric
--- proj-6.2.0.orig/src/projections/mbtfpp.cpp	2019-05-06 07:12:09.000000000 +0200
+++ proj-6.2.0/src/projections/mbtfpp.cpp	2019-09-24 17:42:27.416670200 +0200
@@ -7,7 +7,7 @@
 PROJ_HEAD(mbtfpp, "McBride-Thomas Flat-Polar Parabolic") "\n\tCyl, Sph";
-#define CS  .95257934441568037152
+#define CSy .95257934441568037152
 #define FXC .92582009977255146156
 #define FYC 3.40168025708304504493
 #define C23 .66666666666666666666
@@ -19,7 +19,7 @@
     PJ_XY xy = {0.0,0.0};
     (void) P;
-    lp.phi = asin(CS * sin(lp.phi));
+    lp.phi = asin(CSy * sin(lp.phi));
     xy.x = FXC * lp.lam * (2. * cos(C23 * lp.phi) - 1.);
     xy.y = FYC * sin(C13 * lp.phi);
     return xy;
@@ -41,7 +41,7 @@
         lp.phi = asin(lp.phi);
     lp.lam = xy.x / ( FXC * (2. * cos(C23 * (lp.phi *= 3.)) - 1.) );
-    if (fabs(lp.phi = sin(lp.phi) / CS) >= 1.) {
+    if (fabs(lp.phi = sin(lp.phi) / CSy) >= 1.) {
         if (fabs(lp.phi) > ONEEPS) {
             proj_errno_set(P, PJD_ERR_TOLERANCE_CONDITION);
             return lp;
--- proj-6.2.0.orig/src/projections/isea.cpp	2019-05-06 07:12:09.000000000 +0200
+++ proj-6.2.0/src/projections/isea.cpp	2019-09-24 17:48:13.835557603 +0200
@@ -668,10 +668,10 @@
 /* convert projected triangle coords to quad xy coords, return quad number */
 static int isea_ptdd(int tri, struct isea_pt *pt) {
-    int             downtri, quad;
+    int             downtri, quadz;
     downtri = (((tri - 1) / 5) % 2 == 1);
-    quad = ((tri - 1) % 5) + ((tri - 1) / 10) * 5 + 1;
+    quadz = ((tri - 1) % 5) + ((tri - 1) / 10) * 5 + 1;
     isea_rotate(pt, downtri ? 240.0 : 60.0);
     if (downtri) {
@@ -679,10 +679,10 @@
         /* pt->y += cos(30.0 * M_PI / 180.0); */
         pt->y += .86602540378443864672;
-    return quad;
+    return quadz;
-static int isea_dddi_ap3odd(struct isea_dgg *g, int quad, struct isea_pt *pt,
+static int isea_dddi_ap3odd(struct isea_dgg *g, int quadz, struct isea_pt *pt,
                             struct isea_pt *di)
     struct isea_pt  v;
@@ -715,40 +715,40 @@
      * you want to test for max coords for the next quad in the same
      * "row" first to get the case where both are max
-    if (quad <= 5) {
+    if (quadz <= 5) {
         if (d == 0 && i == maxcoord) {
             /* north pole */
-            quad = 0;
+            quadz = 0;
             d = 0;
             i = 0;
         } else if (i == maxcoord) {
             /* upper right in next quad */
-            quad += 1;
-            if (quad == 6)
-                quad = 1;
+            quadz += 1;
+            if (quadz == 6)
+                quadz = 1;
             i = maxcoord - d;
             d = 0;
         } else if (d == maxcoord) {
             /* lower right in quad to lower right */
-            quad += 5;
+            quadz += 5;
             d = 0;
-    } else if (quad >= 6) {
+    } else if (quadz >= 6) {
         if (i == 0 && d == maxcoord) {
             /* south pole */
-            quad = 11;
+            quadz = 11;
             d = 0;
             i = 0;
             /* lower right in next quad */
-            quad += 1;
-            if (quad == 11)
-                quad = 6;
+            quadz += 1;
+            if (quadz == 11)
+                quadz = 6;
             d = maxcoord - i;
             i = 0;
             /* upper right in quad to upper right */
-            quad = (quad - 4) % 5;
+            quadz = (quadz - 4) % 5;
             i = 0;
@@ -756,11 +756,11 @@
     di->x = d;
     di->y = i;
-    g->quad = quad;
-    return quad;
+    g->quad = quadz;
+    return quadz;
-static int isea_dddi(struct isea_dgg *g, int quad, struct isea_pt *pt,
+static int isea_dddi(struct isea_dgg *g, int quadz, struct isea_pt *pt,
                      struct isea_pt *di) {
     struct isea_pt  v;
     double          hexwidth;
@@ -768,7 +768,7 @@
     struct hex      h;
     if (g->aperture == 3 && g->resolution % 2 != 0) {
-        return isea_dddi_ap3odd(g, quad, pt, di);
+        return isea_dddi_ap3odd(g, quadz, pt, di);
     /* todo might want to do this as an iterated loop */
     if (g->aperture >0) {
@@ -793,41 +793,41 @@
     hex_iso(&h);
     /* we may actually be on another quad */
-    if (quad <= 5) {
+    if (quadz <= 5) {
         if (h.x == 0 && h.z == -sidelength) {
             /* north pole */
-            quad = 0;
+            quadz = 0;
             h.z = 0;
             h.y = 0;
             h.x = 0;
         } else if (h.z == -sidelength) {
-            quad = quad + 1;
-            if (quad == 6)
-                quad = 1;
+            quadz = quadz + 1;
+            if (quadz == 6)
+                quadz = 1;
             h.y = sidelength - h.x;
             h.z = h.x - sidelength;
             h.x = 0;
         } else if (h.x == sidelength) {
-            quad += 5;
+            quadz += 5;
             h.y = -h.z;
             h.x = 0;
         if (h.z == 0 && h.x == sidelength) {
             /* south pole */
-            quad = 11;
+            quadz = 11;
             h.x = 0;
             h.y = 0;
             h.z = 0;
-            quad = quad + 1;
-            if (quad == 11)
-                quad = 6;
+            if (quadz == 11)
+                quadz = 6;
             h.x = h.y + sidelength;
             h.y = 0;
             h.z = -h.x;
         } else if (h.y == -sidelength) {
-            quad -= 4;
+            quadz -= 4;
             h.y = 0;
             h.z = -h.x;
@@ -835,35 +835,35 @@
     di->x = h.x;
     di->y = -h.z;
-    g->quad = quad;
-    return quad;
+    g->quad = quadz;
+    return quadz;
 static int isea_ptdi(struct isea_dgg *g, int tri, struct isea_pt *pt,
     struct isea_pt  v;
-    int             quad;
+    int             quadz;
     v = *pt;
-    quad = isea_ptdd(tri, &v);
-    quad = isea_dddi(g, quad, &v, di);
-    return quad;
+    quadz = isea_ptdd(tri, &v);
+    quadz = isea_dddi(g, quadz, &v, di);
+    return quadz;
 /* q2di to seqnum */
-static long isea_disn(struct isea_dgg *g, int quad, struct isea_pt *di) {
+static long isea_disn(struct isea_dgg *g, int quadz, struct isea_pt *di) {
     long             sidelength;
     long             sn, height;
     long             hexes;
-    if (quad == 0) {
+    if (quadz == 0) {
         g->serial = 1;
         return g->serial;
     /* hexes in a quad */
     hexes = lround(pow(static_cast<double>(g->aperture), static_cast<double>(g->resolution)));
-    if (quad == 11) {
+    if (quadz == 11) {
         g->serial = 1 + 10 * hexes + 1;
         return g->serial;
@@ -871,11 +871,11 @@
         height = lround(floor((pow(g->aperture, (g->resolution - 1) / 2.0))));
         sn = ((long)di->x) * height;
         sn += ((long)di->y) / height;
-        sn += (quad - 1) * hexes;
+        sn += (quadz - 1) * hexes;
         sn += 2;
     } else {
         sidelength = lround((pow(g->aperture, g->resolution / 2.0)));
-        sn = lround(floor(((quad - 1) * hexes + sidelength * di->x + di->y + 2)));
+        sn = lround(floor(((quadz - 1) * hexes + sidelength * di->x + di->y + 2)));
     g->serial = sn;
@@ -894,15 +894,15 @@
     long sidelength;
     long d, i, x, y;
 #endif
-    int quad;
+    int quadz;
-    quad = isea_ptdi(g, tri, pt, &v);
+    quadz = isea_ptdi(g, tri, pt, &v);
     if( v.x < (INT_MIN >> 4) || v.x > (INT_MAX >> 4) )
         throw "Invalid shift";
-    hex->x = ((int)v.x << 4) + quad;
+    hex->x = ((int)v.x << 4) + quadz;
     hex->y = v.y;
     return 1;
@@ -914,16 +914,16 @@
         long offset = lround((pow(3.0, g->resolution - 1) + 0.5));
-        d += offset * ((g->quad-1) % 5);
-        i += offset * ((g->quad-1) % 5);
+        d += offset * ((g->quadz-1) % 5);
+        i += offset * ((g->quadz-1) % 5);
-        if (quad == 0) {
+        if (quadz == 0) {
             d = 0;
             i = offset;
-        } else if (quad == 11) {
+        } else if (quadz == 11) {
             d = 2 * offset;
             i = 0;
-        } else if (quad > 5) {
+        } else if (quadz > 5) {
             d += offset;
--- proj-6.2.0.orig/src/iso19111/io.cpp	2019-08-27 00:10:15.000000000 +0200
+++ proj-6.2.0/src/iso19111/io.cpp	2019-09-24 17:19:25.975914267 +0200
@@ -4444,12 +4444,12 @@
     template <class TargetCRS, class DatumBuilderType,
-              class CS = CoordinateSystem>
+              class CSM = CoordinateSystem>
     util::nn<std::shared_ptr<TargetCRS>> buildCRS(const json &j,
                                                   DatumBuilderType f) {
         auto datum = (this->*f)(getObject(j, "datum"));
         auto cs = buildCS(getObject(j, "coordinate_system"));
-        auto csCast = util::nn_dynamic_pointer_cast<CS>(cs);
+        auto csCast = util::nn_dynamic_pointer_cast<CSM>(cs);
         if (!csCast) {
             throw ParsingException("coordinate_system not of expected type");
@@ -4457,7 +4457,7 @@
                                  NN_NO_CHECK(csCast));
-    template <class TargetCRS, class BaseCRS, class CS = CoordinateSystem>
+    template <class TargetCRS, class BaseCRS, class CSM = CoordinateSystem>
     util::nn<std::shared_ptr<TargetCRS>> buildDerivedCRS(const json &j) {
         auto baseCRSObj = create(getObject(j, "base_crs"));
         auto baseCRS = util::nn_dynamic_pointer_cast<BaseCRS>(baseCRSObj);
@@ -4465,7 +4465,7 @@
             throw ParsingException("base_crs not of expected type");
         if (!csCast) {
--- proj-6.2.0.orig/src/projections/hatano.cpp	2019-05-06 07:12:09.000000000 +0200
+++ proj-6.2.0/src/projections/hatano.cpp	2019-09-24 17:41:51.900833050 +0200
@@ -11,7 +11,7 @@
 #define EPS 1e-7
 #define ONETOL 1.000001
 #define CN  2.67595
-#define CS  2.43763
+#define CSz 2.43763
 #define RCN 0.37369906014686373063
 #define RCS 0.41023453108141924738
 #define FYCN    1.75859
@@ -28,7 +28,7 @@
     int i;
     (void) P;
-    c = sin(lp.phi) * (lp.phi < 0. ? CS : CN);
+    c = sin(lp.phi) * (lp.phi < 0. ? CSz : CN);
     for (i = NITER; i; --i) {
         lp.phi -= th1 = (lp.phi + sin(lp.phi) - c) / (1. + cos(lp.phi));
         if (fabs(th1) < EPS) break;
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190925/3d65f280/attachment.txt>
More information about the PROJ mailing list
