[PROJ] Minor suggestion for AuthorityFactory::getDescriptionText(code)
Martin Desruisseaux martin.desruisseaux at geomatys.com
Mon Sep 30 02:27:00 PDT 2019
Hello
In the C++ API, the documentation of
AuthorityFactory::getDescriptionText said: "In case of several objects
of different types with the same code, one of them will be arbitrarily
selected." This is fine. But the following code with PROJ 6.2.0:
    factory->getDescriptionText("3395");
returns /"Germany - Saxony - west of 13.5°E"/ while I would have
expected /"WGS 84 / World Mercator"/. Technically the result is conform
to PROJ documentation since the former is an Area object with EPSG:3395
code, and the later is a ProjectedCRS object also with EPSG:3395 code.
But I suggest that in such case where different kinds of object have the
same EPSG code, precedence is given to the CRS.
Likewise, getDescriptionText("4326") currently produces /"USA -
Wisconsin - Douglas"/. I have not yet verified if such precedence should
also be enforced in AuthorityFactory::createObject.
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190930/16e59837/attachment.html>
More information about the PROJ mailing list
