[PROJ] Vertical CRS transformations and vertical grid shift
Even Rouault even.rouault at spatialys.com
Thu Apr 16 09:26:20 PDT 2020
> Final question (sorry about that):
> Are you aware of any involvement of this kind of reprojection in gdal_warp
> processing?
> I mean, I just did a test by building PROJ master and GDAL 3.1 against that
> PROJ version and tried a
> gdalwarp -s_srs "EPSG:31255+5778" -t_srs "EPSG:3035+9274" dem.tif
> warpeddem.tif
> Is it expected to reproject the DEM values? :-)
No. Well, this is a bit more complicated than this simple "no". There is actually a special case
in GDAL mentionned in
https://gdal.org/programs/gdalwarp.html#cmdoption-gdalwarp-t-srs :
"Starting with GDAL 2.2, if the SRS has an explicit vertical datum that points to a PROJ.4
geoidgrids, and the input dataset is a single band dataset, a vertical correction will be applied
to the values of the dataset."
But this was in a pre PROJ 6 era, and geoidgrids are no longer used when expanding EPSG
codes (for good reasons). So you would need to provide an explicit PROJ.4 string to make
that work. And this would only work between a geographic 3D CRS and a compoundCRS, not
between two compound CRS like this use case.
So in that use case, you'd have for example to reproject the height shift grid itself to the
same bounds and resolution of the target raster, and use gdal_calc for example to apply the
shift.
I had a discussion a few months ago with someone interested in this GDAL 2.2 behaviour to
work with PROJ 6, but that didn't go further.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200416/4686dffb/attachment.html>
More information about the PROJ mailing list
