[PROJ] Bug in unit conversion using cs2cs and transformations from registries?
Xavier Collilieux xavier.collilieux at ensg.eu
Wed Aug 5 04:48:30 PDT 2020
Dear Even,
Thank you for your prompt reply.
And congratulations to all developers for this software,
Best regards,
-          Xavier
De : Even Rouault [mailto:even.rouault at spatialys.com]
Envoyé : mercredi 5 août 2020 13:25
À : Xavier Collilieux
Cc : proj at lists.osgeo.org
Objet : Re: [PROJ] Bug in unit conversion using cs2cs and transformations from registries?
Arg wrong list...
---------- Forwarded Message ----------
Subject: Re: [gdal-dev] [PROJ] Bug in unit conversion using cs2cs and transformations from registries?
Date: mercredi 5 août 2020, 12:52:14 CEST
To: Xavier Collilieux <xavier.collilieux at ensg.eu>
CC: gdal-dev at lists.osgeo.org
(Adding back the list in CC)
> Thank you for your quick reply and valuable comments. I should have read the
> documentation more deeply, this is indeed written in the documentation of
> cs2cs at the end but I was so sure that cs2cs behaves as projinfo would
> tell that I missed it. * ***** ***** ** ** ***** ******* **** ***** ** ***
> **** **** *** ************** **** ******** lists.
> Another questions, I did not find the answer in the documentation. In case
> of multiple available transformations, do I have a way with cs2cs to tell
> the one I want please? For example "projinfo -s EPSG:4326 -t ESRI:102586"
> provides two output transformations. Do I have the possibility to tell to
> cs2cs that I want the second one? If said differently, instead of giving
> input and ouput crs to cs2cs, can I provide only the transformation name or
> provide the transformation name in addition to the input and output CRS?
> Here "Inverse of NTF to WGS 84 (1) + NTF_Lambert_Zone_II" for example, the
> second field I got using --summary option (= WKT2 CONCATENATEDOPERATION
> name).
You have to use cct with the PROJ pipeline emitted by projinfo to control precisely which
transformation you want to use
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200805/c1e64cb7/attachment-0001.html>
More information about the PROJ mailing list
