[PROJ] Knowing if geoid undulation is applied in C++
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Dec 3 03:51:40 PST 2020
Hi
Let me ask this in 3 levels (all in C++):
- Given two CRS via WKT, is there any way to know if the transformation
from one to the other is applying a geoid undulation?
- ... if the transformation is applying any grid file transformation?
- ... when I run it from GDAL?
I am not using the network functionality to request grid files.
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201203/33e52bd5/attachment.html>
More information about the PROJ mailing list
