[PROJ] 7.2.1 RC1 ob_tran changes break existing logic
Roger Bivand Roger.Bivand at nhh.no
Mon Dec 28 01:18:15 PST 2020
News item:
createOperation(): make it work properly when one of the CRS is a BoundCRS
of a DerivedGeographicCRS (+proj=ob_tran +o_proj=lonlat +towgs84=....)
(#2441)
appear to break:
(crds <- matrix(data=c(9.05, 48.52), ncol=2))
(a <- project(crds, paste("+proj=ob_tran +o_proj=longlat",
  "+o_lon_p=-162 +o_lat_p=39.25 +lon_0=180 +ellps=sphere +no_defs"),
   use_ob_tran=TRUE, verbose=TRUE))
stopifnot(isTRUE(all.equal(a, matrix(c(-5.917698, -1.87195), ncol=2),
   tolerance=.Machine$double.eps ^ 0.25)))
completely in the R rgdal package. ob_tran has always needed special
casing, because of the reverse invert direction, but this change is a
major regression. The operation on input 9.05 48.52 should return
-5.917698 -1.87195 but now chooses coordOp: +proj=noop +ellps=GRS80. In
  7.2.0, the chosen coordOp is (and probably should be):
+proj=pipeline +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +inv
+proj=ob_tran +o_proj=longlat +o_lon_p=-162 +o_lat_p=39.25 +lon_0=180
+ellps=sphere +step +proj=unitconvert +xy_in=rad +xy_out=deg
The NEWS item does not lead one to expect this regression.
Hope some light can be thrown on this and that release will not be
rushed.
Best wishes,
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ mailing list
