[PROJ] Help in setting proj parameters for an old map
aborruso aborruso at gmail.com
Sun Feb 2 15:14:49 PST 2020
I have discovered these fantastic public domains maps
https://legacy.lib.utexas.edu/maps/ams/italy_50k/
If you open a map you can read [1] that the projection is a Lambert Conic
Conformal and you have also the lat_0, lon_0, the Spheroid, the x_0 and the
y_0 of the map.
For a [2] LCC projection the lat_1 parameter (first standard parallel) is
required and it's possible to set also a second standard parallel (lat_2).
First question:
- what's the right lat_1 for this map?
- is it better to set also the lat_2? And if it's yes, what's the right one?
Thank you
[1
]https://user-images.githubusercontent.com/7631137/73595475-78b75080-4519-11ea-9c79-1968126c136d.png
[2] https://proj.org/operations/projections/lcc.html
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
More information about the PROJ mailing list
