[PROJ] "Fallback" support for transformations
Even Rouault even.rouault at spatialys.com
Tue Feb 4 04:52:25 PST 2020
Hi Nyall,
As in QGIS not all coordinate transformations need a geodetic-class level of
accuracy, one aspect you didn't mention and that should probably be taken into
account is the desired final accuracy, which can be linked with the current
map scale.
One factor to also consider is the amount of shift introduced by a
transformation. But this information is not easily available. This is, I
believe, at worse 200 meters when transforming from old systems to new ones,
and much smaller for transformations between more recent systems (at least for
Earth based transformation... No idea for potential future non-Earth
transformations ...)
Doing a quick computation, at 1/1,000,000 scale, and 96 DPI screen resolution,
a pixel represents 1e6 / (96 / 0.0254) = 264 m. So for scales equal or smaller
to that, the effect of any datum transformation is invisible at screen.
Now, if for a given (A,B) tuple of source and target CRS, you've a grid-based
transformation and a Helmert one, then the difference in results between both
is probably at worse of the order of 5 m (and often < 1 m).
So the difference between both would only start being visible for scales equal
or larger than 1/25,000 ( 25000 / (96 / 0.0254) = 6.6 m)
That would mean that, when doing a coordinate transformation in QGIS, if you
had a hint of the scale for which it is intended, then you could decide if you
can just blindly use proj_create_crs_to_crs_from_pj() or not.
(Regarding what Jochem describes for the Dutch transformation, the variant
with the fading out is indeed a smart approach, but too smart to be encoded in
the EPSG database (at least currently), and thus being automatically proposed
by PROJ in a proj_create_crs_to_crs_from_pj() / proj_create_operations() use
case. Could probably be done with a custom entry in the PROJ db, but that's
another topic. So for now, you need to specify "at hand" such PROJ pipeline. )
Even
http://www.spatialys.com
More information about the PROJ mailing list
