[PROJ] "Fallback" support for transformations
Joel Haasdyk joel.haasdyk at customerservice.nsw.gov.au
Tue Feb 4 20:01:04 PST 2020
Option 4: 'make use of a fallback transform opt-in'
is what I have heard expressed most often as the  desired functionality when discussing this issue in the past,
and certainly gets my vote.
As already mentioned, Option 4:
    + offers an easy solution to users for the problem encountered,
    + replicates existing options/functionality in other software (such as FME) [which makes it familiar, not necessarily correct].
    + is not likely to return significantly different transformations between adjacent points,
       (if a reasonable backup is suggested and employed)...
       That said, it will still return a (small?) step at the grid extent...  [not many complaints received to date]
        A few ways around this could be to:
        (1) have the grid define its own recommended fall-back transformation,
              and then have the grid extents equivalent to that fallback.
        (2) have the software provide an interpolation for a defined distance away from the grid.
The Netherlands approach discussed is interesting indeed. A few questions remain before common adoption:
    + what distance would be appropriate / conventional for the fade to the fallback / null Tf?
    + what extent is appropriate for the fallback portion of the grid. (Did you say global?)
    + How to best define the transformation 'extent'?
    + I believe that a similar effect could be produced for any grid shift file by employing a sufficiently sparse 'parent grid' (within the same NTv2 gsb file) equivalent to the fallback. The grid interpolator would then correctly fade to the fallback between the original grid and the new.  That said, I'm not sure how many people actually use parent and child grids in their GSB.
Joel Haasdyk | GDA2020 Implementation Program Manager (NSW)
Spatial Services | Department of Customer Service
p (02) 87376322 | m 0427 229 589
e Joel.Haasdyk at customerservice.nsw.gov.au
w www.spatial.nsw.gov.au
Level 14 West, McKell Building, 2-24 Rawson Place, Sydney NSW 2000
https://www.icsm.gov.au/gda2020 (FAQs & Forum)
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Wednesday, 5 February 2020 10:09 AM
To: Nyall Dawson <nyall.dawson at gmail.com>
Cc: PROJ <proj at lists.osgeo.org>
Subject: Re: [PROJ] "Fallback" support for transformations
> While that approach could work for map rendering, it's not without
> issues. E.g. a point layer dataset with some points outside the extent
> of the grid -- when viewed at small scales you'll see all points, then
> as you zoom in past a certain threshold you'll suddenly lose the
> outside points when the grid shift kicks in. That's definitely going
> to lead to user confusion. It also won't help with other
> transformation tasks like layer exports, because we don't know the
> intended scale for the output we'd always have to use the
> user-specified grid based operation (and result in more bug reports:
> "i can see the points in the canvas, but when I save the layer I only
> get some from the centre of my map in the saved file").
Hard/impossible to make everybody happy on that subject. I would probably suggest going to your 2. behaviour (always return something, which was pretty much the behaviour with PROJ < 6), being the default. With an advanced setting for advanced users that want maximum geodetic pedantism to go to mode 1.
The cases where the grid based transformation are - generally (see below note)
- in situations where points are outside of the area of use of the CRS (or are of use of the transformation), so you don't care a lot about accuracy of the transformation for those, because it is essentially unknown.
Side note:
There are a few cases also where the precise selection of a given transform / grid is not the ideal choice. For example (can't really think about another
one) for the NAD83 -> NAD83(HARN) transformation, the NADCON4 grids used by PROJ are per US state. So, with selection of a single transformation, if you want to transform a dataset covering more than one US state, you're stuck.
That's a annoyance that the data producer realized, and NADCON5 grids are for the whole conterminous US (but those are not integrated in PROJ for now)
Even
https://clicktime.symantec.com/37K99JRAW4KNFbsYyyR4m177Vc?u=http%3A%2F%2Fwww.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://clicktime.symantec.com/32H699CiEohhsWYWncgFZtW7Vc?u=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fproj
This email message and any attached files is confidential and intended solely for the use of the individual or entity to whom it is addressed and may contain information that is privileged, confidential and/or exempt from disclosure under applicable law. If you have received this email in error, delete all copies and notify the sender.
This email is subject to copyright. No part of it should be reproduced, published, communicated or adapted without the copyright owner's written consent. No employee or agent is authorised to conclude any binding agreement on behalf of the Department of Customer Service (DCS) by email without express written confirmation.
The views or opinions presented in this email are solely those of the author and do not necessarily represent those of the DCS. DCS accepts no liability for any loss or damage arising from the use of this email and the recipient should check this email and any attached files for the presence of viruses.
More information about the PROJ mailing list
