[PROJ] Proper projection system for Aruba
Jelmer Baas Jelmer.Baas at speerit.nl
Fri Feb 7 07:00:34 PST 2020
Hello,
I'm trying to convert coordinates from what seems to be a custom projection system in Aruba, without much luck.
In their drawings, they have data around 3000, 18000. Whatever existing projection system I use (EPSG 24819, EPSG 32619), I end up at a completely different location.
For example:
echo 2936 18088 | cs2cs +proj=utm +zone=19 +ellps=intl +towgs84=-216.408,279.243,-203.231,-8.56912,40.8756,-12.5593,15.8909 +units=m +to +proj=webmerc +datum=WGS84
-8178296.58     17850.76 22.52
echo 2936 18088 | cs2cs +proj=utm +ellps=intl +towgs84=-216.408,279.243,-203.231,-8.56912,40.8756,-12.5593,15.8909 +units=m +to +proj=webmerc +datum=WGS84
-830835.88      16729.91 101.08
This is way outside the expected area. In 3857, the data should be somewhere between
-7800000, 1417000
-7777000, 1393000
I do have the attached ".gtf" files, but I'm unsure how to apply this in proj. Is the above string correct? What am I missing?
Any help would be greatly appreciated.
Regards,
Jelmer Baas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200207/6f8bb8d0/attachment.html>
Type: application/octet-stream
Desc: WGS_1984_to_Transverse_Mercator_Aruba_RC.gtf
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200207/6f8bb8d0/attachment.obj>
Desc: Transverse_Mercator_Aruba_to_WGS_1984_RC.gtf
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200207/6f8bb8d0/attachment-0001.obj>
More information about the PROJ mailing list
