[PROJ] GRS80 ellipsoid off-center
Clifford J Mugnier cjmce at lsu.edu
Fri Feb 7 11:44:23 PST 2020
No.  Same ellipsoid, same name.  Different DATUMS, different names.
Get Outlook for iOS<https://aka.ms/o0ukef>
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Pierre Abbat <phma at bezitopo.org>
Sent: Friday, February 7, 2020 1:30:10 PM
To: proj at lists.osgeo.org <proj at lists.osgeo.org>
Subject: [PROJ] GRS80 ellipsoid off-center
I'm at the North Carolina surveyors' conference, and yesterday I attended the
talk about the new coordinate systems coming in 2022. The projection will
still be conformal conic, with some changes. There will be one parallel and a
scale factor instead of two parallels. (The representations are equivalent,
and I've written code that converts two parallels into one parallel and a
scale factor.) The false easting will be a round number in metric rather than
feet converted to meters and rounded to the centimeter. And the ellipsoid will
be centered at the center of mass of the earth, rather than a few meters off.
I asked the speaker what name to use to distinguish the two ellipsoids. He
didn't know, said they're both GRS80. I mentioned that the Greek ellipsoid
(HGRS87, but I didn't remember the name at the moment) has the same shape, but
is offset to fit Greece better, and has its own name. Is there a retronym to
distinguish the previous GRS80, which turned out to be slightly offset, from
GRS80 centered at the center of the earth?
Pierre
La sal en el mar es más que en la sangre.
Le sel dans la mer est plus que dans le sang.
PROJ mailing list
PROJ at lists.osgeo.org
https://nam04.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fproj&data=02%7C01%7Ccjmce%40lsu.edu%7Cef52dce1f4474253c66f08d7ac0434c1%7C2d4dad3f50ae47d983a09ae2b1f466f8%7C0%7C0%7C637167006377571486&sdata=uDIfzYAQrFDJuIoQ1zsuUjy3vf1l8oPpEmCZiID4jSM%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200207/f372fe32/attachment-0001.html>
More information about the PROJ mailing list
