[PROJ] Transformation for local grid
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Mon Feb 10 01:23:19 PST 2020
Hi Pierre,
Your horizontal transformation is in geographic (angular) coordinates. So you have to do that before the projection to coordinates in metres.
Regard, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Pierre Chaponniere
Sent: maandag 10 februari 2020 10:11
To: proj at lists.osgeo.org
Subject: [PROJ] Transformation for local grid
Dear all,
I am struggling to elaborate a pipeline with proj v6.3 that would transform lat long coordinates to a local grid system.
From what I see, I have all the required parameters, so I did a 3 step pipeline :
1/ transform from lat long wgs84 to projected using tmerc.
2/ run horizontal transformation which is a rotation around an origin - I was thinking of using the the Molobadekas transform for this purpose
3/ vertical shift for which I have an origin as well, east and north slope entries in ppm - i still need to figure how I'll pass this one...
So my proj line so far looks like this :
proj +proj=pipeline +step +proj=tmerc +lat_0=-1.90 +lon_0=115.90 +y_0=538.374 +x_0=5200.27 +ellps=GRS80 +step +proj=molobadekas +convention=coordinate_frame +x=-9.85881089465147 +y=-0.172038726321603 +s=17.60710142 +rz=1485.3205006576768028 +px=5225.30897756133 +py=-830.070127940344
But I keep on having errors as 'malformed pipeline' or 'non-angular input coordinates'...
Even trying to pass the Molobadekas transform on its own, I struggle...
Do you see anything that I am doing totally wrong here ?
Would be really appreciated to have your insight on this !
Thanks heaps,
Best regards,
Pierre C
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200210/fdeddd08/attachment.html>
More information about the PROJ mailing list
