[PROJ] PROJ 6.3.1RC1
Even Rouault even.rouault at spatialys.com
Mon Feb 10 02:24:34 PST 2020
I've prepared a PROJ 6.3.1 RC1:
https://download.osgeo.org/proj/proj-6.3.1RC1.tar.gz
https://download.osgeo.org/proj/proj-6.3.1RC1.tar.gz.md5
https://download.osgeo.org/proj/proj-6.3.1RC1.zip
https://download.osgeo.org/proj/proj-6.3.1RC1.zip.md5
See the release notes below.
Please test the release candidates and report back any problems you
may encounter.
Even
6.3.1 Release Notes
 Updates
 o Update the EPSG database to version 9.8.6
 o Database: add mapping for gg10_smv2.mnt and gg10_sbv2.mnt French grids
 o Database: add mapping for TOR27CSv1.GSB
 Bug fixes
 o Fix wrong use of derivingConversionRef() that caused issues with use of
   +init=epsg:XXXX by GDAL (affecting R spatial libraries) or in MapServer
 o fix exporting CoordinateSystem to PROJ JSON with ID
 o projinfo: use No. abbreviation instead of UTF-8 character (#1828)
 o CompoundCRS::identify(): avoid exception when horiz/vertical part is a
   BoundCRS
 o createOperations(): fix dealing with projected 3D CRS whose Z units !=
metre
 o WKT1_GDAL export: limit datum name massaging to names matching EPSG (#1835)
 o unitconvert with mjd time format: avoid potential integer overflow
  (ossfuzz 20072)
 o ProjectedCRS::identify(): fix wrong identification of some ESRI WKT linked
   to units
 o Database: add a geoid_like value for proj_method column of
grid_alternatives,
   fix related entries and simplify/robustify logic to deal with EPSG
   'Geographic3D to GravityRelatedHeight' methods
 o Fix ingestion of +proj=cea with +k_0 (#1881)
 o Fix performance issue, affecting PROJ.4 string generation of EPSG:7842
   (#1913)
 o Fix identification of ESRI-style datum names starting with D_ but without
   alias (#1911)
 o cart: Avoid discontinuity at poles in the inverse case (#1906)
 o Various updates to make regression test suite pass with gcc on i386 (#1906)
http://www.spatialys.com
More information about the PROJ mailing list
