[PROJ] Motion: promote PROJ 6.3.1RC1 to final release
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Wed Feb 12 04:55:42 PST 2020
Bas, Thanks for the explanation.
That the test exceeds the 0.001 m margin, was expected. The 2018 horizontal grid includes a redefinition of RD, that results in changes up to 0.010 m within the land borders of the Netherlands. The 2018 vertical grid is a new estimate of the geoid which can differ up to 0.025 m with the 2004 estimate of the 2008 grid. For the 2018 grids, the new self-validation data should be used instead.
Regards, Jochem
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Bas Couwenberg
Sent: woensdag 12 februari 2020 13:29
To: proj at lists.osgeo.org
Subject: Re: [PROJ] Motion: promote PROJ 6.3.1RC1 to final release
On 2020-02-12 13:07, Bas Couwenberg wrote:
> On 2020-02-12 12:47, Lesparre, Jochem wrote:
>> And why aren't at least the
>> 2008 grids used instead? It looks like cs2cs EPSG:4937 +to EPSG:7415
>> uses no grid at all, but a 7 parameter transformation, introducing
>> errors up to 25 cm horizontally and large errors vertically.
> If I understand correctly the grids will only be used by cs2cs if they
> are locally available, so you need to have the grids installed in
> PROJ_LIB already.
> The first option suggested by projinfo 6.3.1 used the 2018 grids, but
> this may not have been the solution used by cs2cs.
Just tested with PROJ_DEBUG=5 and it uses the 2018 grids if available, but the margin is still exceeded.
  Test:   01 Texel
  Exec:   cs2cs EPSG:4937 +to EPSG:7415 -f %.4f
  Input:  53.160753042 4.824761912 42.8614
  STDERR: pj_open_lib(proj.db): call fopen(/usr/share/proj/proj.db) - succeeded
  pj_open_lib(rdtrans2018.gsb): call
fopen(/usr/share/proj/rdtrans2018.gsb) - succeeded
  pj_open_lib(nlgeo2018.gtx): call fopen(/usr/share/proj/nlgeo2018.gtx) - succeeded
  Output: 117380.1232     575040.3400 0.9794
  Expect: 117380.1200     575040.3400 1.0000
  x coordinate exceeds 0.001 meters: 0.00320000000647269
  NAP exceeds 0.001 meters: 0.0206
  Test FAILED: From ETRS89 to RD/NAP - 01 Texel
These are the expected values as documented in the 2008 documentation:
https://salsa.debian.org/debian-gis-team/proj-rdnap/raw/upstream/2008/Use%20of%20RDTRANS2008%20and%20NAPTRANS2008.pdf
Kind Regards,
Bas
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ mailing list
