[PROJ] Adding new projection to Proj4
Jeff McKenna jmckenna at gatewaygeomatics.com
Sun Feb 16 04:41:33 PST 2020
Hi Alessandro,
A new projection can be added into the EPSG registry by filing a change
request at: http://www.epsg.org/EPSGDataset/Makechangerequest.aspx
I have went through that process several times now, to add a new
projection into EPSG, that is then automatically leveraged by software
projects, such as PROJ.  Of course it takes time, first for the EPSG
committee to review your request, and then also for the new projection
to propagate to all software projects.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-02-16 3:38 a.m., Alessandro Burini wrote:
> Hello,
> My name is Alessandro Burini and I am working at Eumetsat, Germany. I
> have been a user of proj4 for many years and I am now facing a new
> challenge.
> Starting from the work of S. Millis
> (https://www.spiedigitallibrary.org/conference-proceedings-of-spie/9218/92180C/The-ground-track-oblique-Cassini-projection-used-for-producing-VIIRS/10.1117/12.2060760.short?SSO=1),
> we prototyped a C++ and python version of the Ground Track Oblique
> Cassini projection and we would like to integrate it into proj4. Is this
> something feasible?
> We have already contacted the author of the paper to request the
> permission of implementing such projection and, since we started from a
> published paper, we had the permission to use it.
> We think that the integration of such projection into proj4 would
> benefit us and the entire user community.
> Regards
More information about the PROJ mailing list
