[PROJ] PROJ 7.0.0RC1
Kristian Evers kristianevers at gmail.com
Mon Feb 17 23:08:35 PST 2020
> On 18 Feb 2020, at 05:32, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 2/17/20 10:11 PM, Kristian Evers wrote:
>> This also marks the last release of the proj-datumgrid series which has been superseded by
>> proj-data. The proj-datumgrid repository will be archive once PROJ 7.0.0 is released in its final
>> form. The proj-datumgrid packages are updated this last time to extent the lifetime of the PROJ 6
>> branch a little bit.
> What about possible future changes to the grids in proj-datumgrid
> itself? Those are still required for the PROJ tests are they not?
> The primary purpose of the proj-datumgrid was to have that content
> version controlled, the secondary purpose was to collect more regional
> grids to have them more easily available to users. The latter is now
> provided by the CDN, which just leaves the former use case.
The grids provided on the CDN are versioned controlled in the PROJ-data
repository: https://github.com/OSGeo/proj-data <https://github.com/OSGeo/proj-data>
The purpose is the same as for the proj-datumgrid, this is just a fresh start
following the changes caused by RFC4.
/Kristian
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200218/bbbce910/attachment.html>
More information about the PROJ mailing list
