[PROJ] Questions about ESRI WKT -> proj operation mappings
Nyall Dawson nyall.dawson at gmail.com
Sun Feb 23 15:12:40 PST 2020
Hi list,
While attempting to fill some of the gaps in the ESRI WKT to proj
operation mapping file
(https://github.com/OSGeo/PROJ/blob/master/scripts/build_esri_projection_mapping.py)
I've hit some questions:
- ESRI Hammer_Aitoff projection: is this the same as proj's "hammer",
but with the fixed W=0. parameter mentioned in
https://proj.org/operations/projections/hammer.html?
- Flat_Polar_Quartic: is this the same as the McBryde-Thomas
Flat-Polar Quartic exposed by proj?
- "Cube": I'm guessing this is
https://pro.arcgis.com/en/pro-app/help/mapping/properties/cube.htm,
and differs from https://proj.org/operations/projections/qsc.html
because qsc only supports a single face at a time..?
Anyone able to assist here?
Nyall
More information about the PROJ mailing list
