[PROJ] Disable .local in 7.0.0RC default search paths
Roger Bivand Roger.Bivand at nhh.no
Mon Feb 24 04:05:49 PST 2020
On Mon, 24 Feb 2020, Kristian Evers wrote:
>> On 23 Feb 2020, at 19:50, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> On Sun, 23 Feb 2020, Even Rouault wrote:
>>>> This is a very useful clarification, thanks. Looking at
>>>> networkfilemanager.cpp, I can see plenty of functions giving insight when
>>>> I need it. For now, I can add an rgdal load-time comment from
>>>> pj_context_is_network_enabled() to confirm that the network functionality
>>>> is disabled.
>>> This is an internal function. I've just submitted
>>> https://github.com/OSGeo/PROJ/pull/1967 to expose it as an exported function
>> Thanks very much, just got there. Will this get into 7.0.0RC2?
> Yes.
Great! Building rgdal from the PROJ master, I can now report status:
> library(rgdal)
Loading required package: sp
rgdal: version: 1.5-6, (SVN revision 944)
  Geospatial Data Abstraction Library extensions to R successfully loaded
  Loaded GDAL runtime: GDAL 3.1.0dev-e52a02d452, released 2020/02/21
  Path to GDAL shared files: /usr/local/share/gdal
  GDAL binary built with GEOS: TRUE
  Loaded PROJ.4 runtime: Rel. 7.0.0, March 1st, 2020, [PJ_VERSION: 700]
  Path to PROJ.4 shared files:
/home/rsb/.local/share/proj:/usr/local/share/proj:/usr/local/share/proj
  PROJ CDN enabled: FALSE
  Linking to sp version: 1.4-0
Roger
> /Kristian
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ mailing list
