[PROJ] included tests and grids
Even Rouault even.rouault at spatialys.com
Sun Jan 5 14:11:19 PST 2020
> So it would be nice if either the tests expected what seems to be the
> standard set of extra grids (i.e., what is listed at
> https://proj.org/download.html under "Current Release"), or somehow
> avoided reading things that aren't part of base.
https://github.com/OSGeo/PROJ/pull/1822 should fix this issue
http://www.spatialys.com
More information about the PROJ mailing list
