[PROJ] Closing in on PROJ 7 release date
Greg Troxel gdt at lexort.com
Mon Jan 13 08:17:38 PST 2020
Even Rouault <even.rouault at spatialys.com> writes:
>> 3. ... and possibly RFC4-related changes regarding grid management (not
>> sure about this one yet)
> None at the API level. There has just been removal of 2 esoteric
> functionality: the undocumented +catalog and the ancient & no longer used
> CTable format.
> Depending on the outcome of the discussion I've opened on using
> proj-datumgrid-geotiff, there might be changes in how dependencies to grid
> packages are expressed (doesn't impact API)
That all sounds fine.  My concern is really
  Given some random package P that uses proj, if I update from 5 to 6,
  or from 6 to 7, does P build (without touching it) or does it build
  with "#define ENABLE_DEPRECATED_FOO", or do I have to mark it broken
  in the packaging system.
More information about the PROJ mailing list
