[PROJ] Closing in on PROJ 7 release date
Greg Troxel gdt at lexort.com
Mon Jan 13 09:20:52 PST 2020
Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
> On 1/13/20 5:15 PM, Greg Troxel wrote:
>> 5 really should still get microreleases for security fixes, if any.  I
>> don't think we've yet arrived at the point where packaging systems can
>> upgrade from 5 to 6 without orphaning packages.  (I'd like to hear where
>> Bas is on this.)
> Upgrading to PROJ 6 will likely require removing some dead projects, we
> had to remove Geo::Proj4 (Perl bindings) and it Geo::Point rdep, along
> with merkaartor from Debian as part of the transition to PROJ 6. And we
> patched vtk6 & vtk7 to use the embedded copy of PROJ4 because only very
> recent VTK releases support proj.h. Several projects like
> The related transition to GDAL 3 also got dans-gdal-scripts, prepair &
> pprepair removed because it's not updated for changes in that.
> With the release of PROJ 7 on the horizon you should really start moving
> to PROJ 6 for NetBSD. Not everything supports proj.h yet, but you can
> build those projects with -DACCEPT_USE_OF_DEPRECATED_PROJ_API_H.
Thanks.  My impression was that I should move to 6 basically now, and
that there would be some orphans, but that they are unmaintained
upstream anyway, but your comments confirm that solidly.
> With the removal of proj_api.h from PROJ 7 there are still some blockers
> like MapServer, SpatiaLite, libosmium and others. From that list only
> MapServer and libosmium are actual blockers for me, I'm willing to
> remove SpatiaLite from Debian if the current lack of stable upstream
> releases with PROJ 6 support remain absent.
> We'll have PROJ6 & GDAL3 in the next Debian stable release, and will
> move to PROJ 7 during the development cycle for the release after that.
Thanks for the note about where you are.
Anybody else doing packaging here?
More information about the PROJ mailing list
