[PROJ] test failure with 6.3.0 geodtest
Greg Troxel gdt at lexort.com
Tue Jan 14 10:26:10 PST 2020
I have narrowed down the geodtest issue.  Thanks very much for your
earlier hint.
With respect to HAVE_C99_MATH, I have (munging the source) basically set
it to 1 in all respects, except that I am using the PROJ-provided
remquox implementation.  Then, tests pass.
In remquox, I added a call to remquo (OS-supplied), and looked for cases
with different output.  There are many, in *n (which I read the docs to
say is an output parameter).  Right now this points to a difference in
NetBSD's remqo from remquox, and it seems the NetBSD implementation is
out of spec, but the spec is slightly hard to follow.  I'll follow up
within NetBSD.
More information about the PROJ mailing list
