[PROJ] OSGeo incubation status
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Jan 24 01:38:58 PST 2020
On 9/10/19 1:50 PM, Sebastiaan Couwenberg wrote:
> On 9/10/19 1:16 PM, Martin Desruisseaux wrote:
>> On EPSG, can we really said that the data fail under MIT license because
>> we do not modify it? The EPSG terms of use said:
>>> You are obliged to inform anyone to whom you provide the EPSG
>>> Facilities of these Terms of Use.
>> So we need to inform users that they can not modify those data without
>> changing the EPSG name. And also that they can not extract the data and
>> sell them alone (without the added value of PROJ or other software).
>> Those conditions are not MIT terms.
> Unless PROJ already modifies the data and doesn't attribute it to the
> EPSG dataset. There is no epsg init file any more, there is proj.db now.
> Not being a lawyer I cannot provide an authoritative answer, only my
> interpretation.
>> The Apache Software Foundation legal team has debated about the
>> permission to include EPSG data in Apache software [3], and our
>> conclusion was that we can not provide them directly. We do that
>> indirectly by providing the data in a "non-free" package and require an
>> explicit action from users (which we try to make as simple as possible)
>> to get them.
> I hope we can prevent this situation with proj, as we'll revert back to
> the one with libgeotiff-epsg which few users installed despite needing it.
> In the worst case scenario proj moves to non-free and everything that
> depends on it to contrib, making them not part of Debian and loose QA
> coverage, autobuilding and the like. This would be very harmful to users.
> I would stick to the working theory until IOGP complains and proves us
> otherwise.
There was an event about the new Dutch grids yesterday, there I spoke
with Roel Nicolai who has been involved with EPSG since the beginning
and drafted the EPSG TOU. He told me that my interpretation of the terms
is incorrect, the MIT license cannot be applied to the SQL files derived
from the EPSG data as done currently. He also strongly urged us to
separate code and data, i.e. don't include the SQL files in the source
tree nor build the database as part of the build process.
To resolve this issue without making PROJ non-free with the adverse
ripple effect on all its dependent projects, we should implement a
process similar to Apache SIS.
Alternatively we need to convince IOPG to dual license the EPSG data
under and DFSG compatible license.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
