[PROJ] Converting NAD83/NADV88 heights to HAE
    Brian Shaw
    brian.shaw at noaa.gov
    Wed Jul  1 18:11:52 PDT 2020
Hi Patrick
NOAA does maintain the NAD 83, NAVD 88 and geoid models, looks like the
typo might be in the readme from anothers email since NGA maintains
WGS84 and EGM08.
I apologize as Im not completely sure on the format of your command but
I think I have it you are passing UTM coordinates in NAD83 to geoid18 to
get an NAVD88 height except that instead of passing an ellipsoid height
you are passing an orthometric height.
To calculate the ellipsoid height you would use the formula h=H+N where
h (ellipsoid height, in this case NAD 83), H (orthometric height, in
this case NAVD 88) and N (geoid height, in this case GEOID18).
You should be providing an ellipsoid height to the geoid to get an
orthometric height.  Maybe its because its the end of my work day that I
cant figure out how to do this in one step but I believe if you provide
0 as the height this will then give you the geoid height for that
location (in geoid18) and you can just add this to your orthometric
height to get the ellipsoid height.  You should get a negative number
since the geoid is all negative for CONUS.
more information about geoid18 can be found here:
https://geodesy.noaa.gov/GEOID/GEOID18/
Hopefully this helps if I think of a way to do it in one command Ill
respond again if someone else doesnt provide a solution.
Cheers
Brian
On 7/1/2020 5:49 PM, Patrick Young wrote:
> Hello,
> I am trying to figure out how to convert some elevations I have into
> heights above ellipsoid via the cs2cs tool.  I am using proj 7.0.1,
> and I've run projsync --all to snag all the grids.
> Here is an example of what isn't working for me:
> echo 565890.947 4192011.754 55 | cs2cs +proj=utm +zone=10 +datum=NAD83
> +units=m +no_defs +geoidgrids=us_noaa_g2018u0.tif +to +proj=utm
> +zone=10 +datum=NAD83 +units=m +vunits=m +no_defs
> 565890.95       4192011.75 55.00
> I am confused as to why the elevation value isn't changing for me.  My
> (extremely limited) understanding is that I am asking for 55m to be
> converted from a height referenced against the NADV88 geoid to one
> referenced against the NAD83 ellipsoid.  Am I using the wrong geoid
> grid?  From the grid readme, it mentions "us_nga_g2018u0.tif :
> Conterminous US, referenced to NAD83(2011). Vertical datum: NAVD88"
> (presumably the nga <-> noaa is a typo in the readme) so I think I'm
> using the right one.
> Thanks for any help,
> Patrick
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Brian Shaw
Rocky Mountain Regional Advisor (CO, MT, WY)
NOAA's National Geodetic Survey (NGS)
Phone # 240-533-9522
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200701/27fdc939/attachment-0001.html>
More information about the PROJ
