[PROJ] Converting NAD83/NADV88 heights to HAE
Patrick Young patrick.mckendree.young at gmail.com
Thu Jul 2 08:07:20 PDT 2020
Thanks everyone for the help.  Now I just need to get it going in gdalwarp!
P
On Thu, Jul 2, 2020 at 7:37 AM Greg Troxel <gdt at lexort.com> wrote:
> Even Rouault <even.rouault at spatialys.com> writes:
> > For projinfo, you need to put the PROJ string inside double quotes, and
> add a +type=crs
> > projinfo "+proj=utm +zone=10 +datum=NAD83 +units=m
> +geoidgrids=us_noaa_g2018u0.tif
> > +type=crs"
> Thanks.  I did not figure that out from reading the projinfo man page.
> It says
>   {object_definition} might be a PROJ string, a WKT string,  a
> AUTHORITY:CODE, or urn:ogc:def:OBJECT_TYPE:AUTHORITY::CODE
> which I guess in hindsight sort of implies a single argument.   The
> {foo} syntax makes sense in hindsight but I didn't grasp this.
> I only find the +type=crs within --identify.
> >> 2) It strikes me that once one moves away from basic 2D datums, the
> >> legacy syntax is dangerous, and people should be encouraged to use a
> >> clearer definition.  Do you agree, and if so I wonder what you think
> >> should be done?
> > The only advantage of it is its compacity, especially for simple things.
> Using EPSG codes or
> > EPSG names for well-known objects is an alternative. Otherwise you have
> to use more
> > verbose syntaxes with WKT or PROJJSON
> that makes sense, but it seems that most people are using things that
> can be defined via EPSG codes, and if so would be better served by
> doing so to reduce confusion.
> >> 3) I didn't realize one caould merge two codes that way to construct a
> >> compound CRS.  That may just be me that doesn't know that, but it might
> >> help to add an example to cs2cs(1).
> > Was already documented for projinfo, but indeed wasn't explicitly
> mentionned for cs2cs.
> > Should be addressed by https://github.com/OSGeo/PROJ/pull/2290
> Great, thanks.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200702/6cb1f141/attachment-0001.html>
More information about the PROJ mailing list
