[PROJ] Supported geographical coordinate formats
Andreas B panden at gmail.com
Fri Jul 3 00:14:41 PDT 2020
Right, so longitude is expected to be in the first input column and
latitude in the second. If you get this wrong proj wont warn you. Got
it, thanks.
PS! Is +proj=latlong the same as +proj=longlat?
Andreas
On Thu, Jul 2, 2020 at 5:57 PM Charles Karney <charles at karney.com> wrote:
> Because PROJ uses the order of the coordinates to distinguish latitude
> and longitude.  E.g.,
>    echo 4N 10W | cs2cs +proj=latlong
>    4dE     10dS 0.000
> On 7/2/20 9:43 AM, Andreas B wrote:
> > Thanks for answering Charles.
> > I'm not sure if I understand. Why would 10W be interpreted as lat = -10?
> > Andreas
> > On Thu, Jul 2, 2020 at 3:33 PM Charles Karney <charles at karney.com> wrote:
> >> One major usability issue with PROJ is that the hemisphere designators
> >> NESW *only* specify the sign of the coordinate.  Thus it's easy for
> >> 10W to be interpreted as lat = -10.  Fixing this would required some
> >> replumbing of PROJ since the two horizontal components would need to
> >> be decoded together.
> >> On 7/2/20 9:17 AM, Andreas B wrote:
> >>> Hi,
> >>> Is there any formal description or definition of what kind of
> >>> geographical coordinate format the proj command line tools support
> >>> (input and output)?
> >>> Several styles are presented in the docs, e.g.
> >>> (https://proj.org/apps/cs2cs.html#using-proj-strings)
> >>> 45d15'33.1" 111.5W
> >>> 45d15.551666667N -111d30
> >>> +45.25919444444 111d30'000w
> >>> Any preferred format?
> >>> Thanks,
> >>> Andreas
> Princeton, NJ
More information about the PROJ mailing list
