[PROJ] API migration - Offset on z-axis
Even Rouault even.rouault at spatialys.com
Thu Jul 16 08:21:25 PDT 2020
Kilian,
> Our team upgraded proj API from 4 to 6.
> We noticed difference between the result when using projection in
> Switzerland (for instance EPSG:2056).
> Here, I try to recap the difference between our implementation:
> *Initial implementation (PROJ 4):*
> // Input: x,y,z be coordinate expressed in EPSG:4978
> projPJ pj_in;
> projPJ pj_out;
> pj_in = pj_init_plus("+init=epsg:4978");
> pj_out = pj_init_plus("+init=epsg:2056");
> pj_transform(pj_in, pj_out, 1, 1, x, y, z);
> *Current implementation (PROJ 6)*
> // Input: PJ_COORD coord expressed in EPSG:4978
> PJ_CONTEXT* context = projContextCreate();
> PJ* p1 = proj_create_crs_to_crs(context, "EPSG:4978", "EPSG:2056", NULL);
> PJ* proj = proj_normalize_for_visualization(context, p1);
> coord = proj_trans(proj , PJ_FWD, coord);
> We noticed that the output using our current implementation yield the
> wrong result: there is an offset along the z-axis.
> Are we doing something wrong?
No, you aren't doing something wrong. This is more a feature/bug of PROJ, and some
ambiguity in how coordinate operations are presented in the EPSG database
First, what can help when you're investigating issue is to use "projinfo" to look at the
pipelines.
For example with latest PROJ master:
projinfo -s EPSG:4978 -t EPSG:2056  -o PROJ
Candidate operations found: 1
Operation No. 1:
unknown id, Conversion from WGS 84 (geocentric) to WGS 84 (geog2D) + Inverse of CH1903+
to WGS 84 (1) + Swiss Oblique Mercator 1995, 1 m, Europe - Liechtenstein and Switzerland
PROJ string:
+proj=pipeline +step +inv +proj=cart +ellps=WGS84 +step +proj=push +v_3 +step +proj=cart
+ellps=WGS84 +step +proj=helmert +x=-674.374 +y=-15.056 +z=-405.346 +step +inv
+proj=cart +ellps=bessel +step +proj=pop +v_3 +step +proj=somerc
+lat_0=46.9524055555556 +lon_0=7.43958333333333 +k_0=1 +x_0=2600000 +y_0=1200000
+ellps=bessel
You can see that there are a push v_3 and pop v_3 steps surrounding the cartesian
conversions and the Helmert transformation. Their effect is to avoid the ellipsoidal height to
be modified during the Helmert transformation.
This behaviour is based on the EPSG dataset presenting the Helmert transformation to be in
the geographic 2D domain, due to the source & target CRS for which the "CH1903+ to WGS
84 (1)" operation is presented being 2D themselves. So for an operation on 2D CRS, changing
ellipsoidal height doesn't make sense as there's no ellipsoidal height for such CRS.
Later discussions with experts at EPSG revealed that the intent is however that when using
the 3D CRS based on those 2D CRS, ellipsoidal height transformation should still be done.
So let's look when using EPSG:4979 (WGS 84 3D geographic) instead of EPSG:4978:
$ projinfo -s EPSG:4979 -t EPSG:2056  -o PROJ
Operation No. 1:
unknown id, Inverse of CH1903+ to WGS 84 (1) + Swiss Oblique Mercator 1995, 1 m, Europe -
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg
+z_in=m +xy_out=rad +z_out=m +step +proj=push +v_3 +step +proj=cart +ellps=WGS84
+step +proj=helmert +x=-674.374 +y=-15.056 +z=-405.346 +step +inv +proj=cart
+ellps=bessel +step +proj=pop +v_3 +step +proj=somerc +lat_0=46.9524055555556
+lon_0=7.43958333333333 +k_0=1 +x_0=2600000 +y_0=1200000 +ellps=bessel
Same behaviour as above due to the fact that even if EPSG:4979 is 3D, EPSG:2056 is 2D.
If adding the --3d switch to force its promotion to 3D:
$ projinfo -s EPSG:4979 -t EPSG:2056  -o PROJ --3d
Operation No. 1:
PROJ string:
+z_in=m +xy_out=rad +z_out=m +step +proj=cart +ellps=WGS84 +step +proj=helmert
+x=-674.374 +y=-15.056 +z=-405.346 +step +inv +proj=cart +ellps=bessel +step +proj=somerc
+ellps=bessel
one can see that there is no more a push / pop v_3.
However if trying the --3d trick with EPSG:4978 this doesn't lead to the expected result
currently. So that part of the behaviour is more a bug on PROJ side.
API wise, --3d behaviour is obtained with using proj_crs_promote_to_3D().
For your particular case, you can either use manually the corrected pipeline without the push
/ pop v_3, or use a more 2-step approach with a first conversion between EPSG:4978 and
EPSG:4979 chained with a transformation between EPSG:4979 and EPSG:2056 promoted to
3D. The correct behaviour on ellipsoidal height when using a Geographic 3D CRS was fixed in
"recent" PROJ 6 or 7 versions, so you'd better using the latest PROJ 7.1.0
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200716/73afe5be/attachment-0001.html>
More information about the PROJ mailing list
