[PROJ] proj-data is 500MB
Jürgen E. Fischer jef at norbit.de
Fri Jul 24 01:00:38 PDT 2020
Hi Bas,
On Fri, 24. Jul 2020 at 09:41:02 +0200, Sebastiaan Couwenberg wrote:
> You could split up the grids per region and only depend on a subset
> (excluding au_*, ca_*, de_* & us_* removes most of the very large grids)
> and suggest the rest for the users to manually install when they need it.
I don't want to exclude de completely - esp. because there are grids that were
previously shipped among it.  The ridiculously large Baden-Württemberg grid
wasn't and must be excluded.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden              https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/39b2c593/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/39b2c593/attachment.ksh>
More information about the PROJ mailing list
