[PROJ] proj-data is 500MB
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jul 24 06:38:35 PDT 2020
For my (MS4W) packaging use I needed a full list of today's grid files
and sizes (351 files, 504 MB), which might be useful to see for other
packagers as they decide how to handle this:
https://gatewaygeomatics.com/dl/proj-data-size-2020-07-24.txt
(of course a cooler way is to use the viewer at https://cdn.proj.org/ )
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-07-24 6:28 a.m., Kristian Evers wrote:
> Installing proj-data only once is the intended default use case. As far
> as I am aware this is how
> all the packaging systems that include proj-data handles this (with
> conda perhaps being the
> exception?).
> As for the rest of the discussion, it is quite difficult to do The Right
> Thing regarding distribution
> of transformation grids. Previously when we provided smaller regional
> packages we got complaints
> because it wasn’t bundled as one big package, now that we do just that
> it is also seen to be a
> problem (by some users at least).
> The current trend is that transformation grids become larger and is used
> more frequently in new
> transformations, so we can reasonable expect the weight of the proj-data
> package to increase
> in the coming years. Even if we again create regional packages they will
> at some point become
> too big to include by default in software like QGIS. That can of course
> be solved by dividing the
> packages into even smaller regions but that very quickly becomes a pain
> to maintain and package.
> The dynamical downloading of grids is really the best we can do to cater
> to the most users. I want
> to encourage everyone to incorporate the dynamic downloading option into
> their software,
> since that will be the most flexible way of providing your users with
> the necessary transformation
> data. I am aware that it in some cases that is difficult to achieve,
> Nyall Dawson has provided good
> arguments for why doing so in QGIS is not as easy as one might expect. I
> hope that can be resolved
> in the future.
> /Kristian
> *From:*PROJ <proj-bounces at lists.osgeo.org> *On Behalf Of *Javier Jimenez
> Shaw
> *Sent:* 24. juli 2020 10:31
> *To:* PROJ at lists.osgeo.org
> *Subject:* Re: [PROJ] proj-data is 500MB
> Just one comment: if you have several programs that use proj-data, and
> each one installs 500 MB, sounds like a waste of space, right?
> Does it make sense to install proj-data only once?
> Regards
> Javier
> El vie., 24 jul. 2020 10:16, Sebastiaan Couwenberg <sebastic at xs4all.nl
> <mailto:sebastic at xs4all.nl>> escribió:
>     On 7/24/20 10:00 AM, Jürgen E. Fischer wrote:
>      > On Fri, 24. Jul 2020 at 09:41:02 +0200, Sebastiaan Couwenberg wrote:
>      >> You could split up the grids per region and only depend on a subset
>      >> (excluding au_*, ca_*, de_* & us_* removes most of the very
>     large grids)
>      >> and suggest the rest for the users to manually install when they
>     need it.
>      > I don't want to exclude de completely - esp. because there are
>     grids that were
>      > previously shipped among it.  The ridiculously large
>     Baden-Württemberg grid
>      > wasn't and must be excluded.
>     Then perhaps split the grids by size similar to the
>     gmt-gshhg-{low,high,full} packages.
>     The gmt package in Debian only Recommends gmt-gshhg-low because of size
>     constraints for OSGeoLive, despite the authors wanting the full package
>     installed by default.
>     Kind Regards,
>     Bas
>       GPG Key ID: 4096R/6750F10AE88D4AF1
>     Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>     _______________________________________________
>     PROJ mailing list
>     PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
More information about the PROJ mailing list
