[PROJ] ESRI:102655 - z-axis in meter insted of us-ft
Kilian Demeulemeester kilian.demeulemeester at yellowscan-lidar.com
Fri Jun 5 08:09:15 PDT 2020
Hi there!
I am using proj c++ api and I have the follwoing question:
When using ESRI:102655, it look like it do not convert the vertical axis
to us-ft. My program output the |z| in meters.
If I generate the proj4 string via |proj_as_proj_string|, I retrieve the
following string :
+proj=lcc +lat_0=36.6666666666667 +lon_0=-105.5 +lat_1=37.2333333333333
+lat_2=38.4333333333333 +x_0=914401.828899998 +y_0=304800.6096
+datum=NAD83 +units=us-ft +no_defs +type=crs
Then, if I add |vunits=us-ft |to the projString, I get the expected
result (z in us-ft!)
Is that a bug or am I doing something wrong ?
Best,
Kilian
Software Developer - R&D
[https://yellowscan-lidar.com/]
1 Chemin de fescau
34980 Montferrier-Sur-Lez - France
Tel: +33 (0)4 11 93 14 06
yellowscan-lidar.com [https://yellowscan-lidar.com/]
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200605/7c31ccbc/attachment.html>
Type: image/png
Desc: x-disclaimer-534644925-0.png
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200605/7c31ccbc/attachment.png>
More information about the PROJ mailing list
