[PROJ] Libtiff-4 error when compiling 7.0.0
Stefano Iacovella stefano.iacovella at gmail.com
Tue Mar 3 02:49:53 PST 2020
Hi all,
I'm upgrading to new release 7.0.0 compiling from sources in a Linux Mint
box.
In the same server I previously installed 6.3.1 with no issues.
When I run the ,/configure command with 7.0.0 I got this error:
checking for SQLITE3... yes
checking for sqlite3... yes
checking for TIFF... configure: error: Package requirements (libtiff-4)
were not met:
No package 'libtiff-4' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables TIFF_CFLAGS
and TIFF_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I checked the packages installed on the server and there is a libtiff5 one.
It seems there is no libtiff-4 package in the repository:
~/sources/proj-7.0.0$ dpkg -l | grep libtiff
ii  libtiff5:amd64                             4.0.9-5ubuntu0.3
                    amd64        Tag Image File Format (TIFF) library
Any hint?
Thank you very much
Stefano
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200303/bff2d24d/attachment.html>
More information about the PROJ mailing list
