[PROJ] Libtiff-4 error when compiling 7.0.0
Stefano Iacovella stefano.iacovella at gmail.com
Tue Mar 3 02:56:52 PST 2020
I just realised what I missed was libtiff5-dev package.
Sorry for the dumb question :(
All the best
Stefano
Il giorno mar 3 mar 2020 alle ore 11:49 Stefano Iacovella <
stefano.iacovella at gmail.com> ha scritto:
> Hi all,
> I'm upgrading to new release 7.0.0 compiling from sources in a Linux Mint
> box.
> In the same server I previously installed 6.3.1 with no issues.
> When I run the ,/configure command with 7.0.0 I got this error:
> checking for SQLITE3... yes
> checking for sqlite3... yes
> checking for TIFF... configure: error: Package requirements (libtiff-4)
> were not met:
> No package 'libtiff-4' found
> Consider adjusting the PKG_CONFIG_PATH environment variable if you
> installed software in a non-standard prefix.
> Alternatively, you may set the environment variables TIFF_CFLAGS
> and TIFF_LIBS to avoid the need to call pkg-config.
> See the pkg-config man page for more details.
> I checked the packages installed on the server and there is a libtiff5
> one. It seems there is no libtiff-4 package in the repository:
> ~/sources/proj-7.0.0$ dpkg -l | grep libtiff
> ii  libtiff5:amd64                             4.0.9-5ubuntu0.3
>                       amd64        Tag Image File Format (TIFF) library
> Any hint?
> Thank you very much
> Stefano
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200303/d25def37/attachment.html>
More information about the PROJ mailing list
