[PROJ] "eck_greif" projection, "libproject"?
Even Rouault even.rouault at spatialys.com
Wed Mar 4 14:11:23 PST 2020
Nyall,
> Does anyone know what the "+proj=eck_greif" mentioned in section 7.2.1
> of http://priede.bf.lu.lv/ftp/pub/TIS/bibliotekas/PROJ.4/libproj4_manual.pdf
> refers to? I can't find any reference to this in master proj code base at
> all. (It's also referenced here:
> https://github.com/Esri/projection-engine-db-doc/blob/master/other/proj4-esr
> i.txt#L154, which is why I'm asking the question)
> The proj4-esri.txt file also states:
> "Names marked with a * are only in the libproject distribution
> Names marked with a @ are only in the PROJ4      distribution"
> (https://github.com/Esri/projection-engine-db-doc/blob/master/other/proj4-es
> ri.txt#L21)
> Does anyone have any clues as to what "libproject distribution" is? I
> can't find anything relevant from my searching, but given the context
> it sounds like some historic proj fork?
This is likely the libproj4, that was forked from PROJ4 in 2002 by Jerry
Evenden when he disagreed with the project directions :
http://libproj4.maptools.org/
Particularly the lbp4_050319S.tar.gz source archive. Unfortunately I can't
find any mention of eck_greif into it.
There's also the
https://github.com/jeffbaumes/jeffbaumes-vtk/tree/master/Utilities/vtklibproj4
sources that Kristian identified in
https://github.com/OSGeo/PROJ/issues/1851#issuecomment-574878542 but no trace
The most promising would be to start from
https://www.javatips.net/api/onebusaway-jmapprojlib-master/src/main/java/com/
jhlabs/map/proj/EckertGreifendorffProjection.java
whose header indicates "This file was semi-automatically converted from the
public-domain USGS PROJ source.
 * Bernhard Jenny, May 07: split Hammer and Eckert-Greifendorff projections."
So, with that hint, looking in PROJ src/projections/hammer.cpp, the projection
name is  "Hammer & Eckert-Greifendorff"
And when comparing hammer.cpp with EckertGreifendorffProjection.java, it seems
Eckert-Greifendorff is actually just "+proj=hammer +W=0.25 +m=1"
End of treasure hunt :-)
(but there must another libproj4 or whatever variant name archive somewhere!)
Even
http://www.spatialys.com
More information about the PROJ mailing list
