[PROJ] libproj4 archived in a github repo [was Re: "eck_greif" projection, "libproject"?]
Even Rouault even.rouault at spatialys.com
Thu Mar 5 12:54:49 PST 2020
> Unfortunately that link is dead. A bit of googling reveals
> https://karczmarczuk.users.greyc.fr/TEACH/InfoGeo/Work/libproj4.3_20081120.t
> ar.bz2
> <https://karczmarczuk.users.greyc.fr/TEACH/InfoGeo/Work/libproj4.3_20081120
> .tar.bz2>
> It seems the file structure is different from the code base Even has put in
> his repostory. I don’t know if that means this code is more recent or not.
Your archive is more recent. It dates from 2008/11/20, whereas the one I found was
from 2005/03/19, with no identified version number (I've verified that there are
actually files modified at that date in the CVS ids, and none afterward.
I've updated my repo to tag both versions, and default as master to one you exhibited.
git is smart enough to detect the file move and different naming conventions (PJ_foo vs proj_foo)
and give a reasonably reviewable (huge) diff between both:
https://github.com/rouault/libproj4/commit/81a8bcb91d1fb9d5c5894286e6fcbef8fa1269bd
http://www.spatialys.com
More information about the PROJ mailing list
