[PROJ] Relevant descrepancies between Sinusoidal and Homolosine
Even Rouault even.rouault at spatialys.com
Tue Mar 10 05:55:08 PDT 2020
On mardi 10 mars 2020 12:42:15 CET Luí­s Moreira de Sousa wrote:
> Hi Even,
> I have not yet checked the formulas from that source, but regarding the
> current Homolosine implementation, its outputs are the expected. So perhaps
> it is applying the spherical Sinusoidal and the ellipsoidal Mollweide?
No, before my PR, that would be the reverse: it would apply the ellipsoidal
Sinusoidal and the (spherical, but there's only spherical implemented)
Mollweide. igh doesn't do real computations by itself: it just dispatches to
the existing sinu or moll methods depending on the input coordinate.
Maybe, a proper fix would probably be add an ellipsoidal formulation to
Mollweide. But igh would then be much more complicated because the dispatching
logic strongly relies on the fact that there's an identity between northing
and latitude from what I can see.
So I guess making sure igh uses spherical formulas for both sinuosidal and
mollweide, as I intented in my PR, is probably better than the current
situation where there's a mix ?
http://www.spatialys.com
More information about the PROJ mailing list
