[PROJ] Can't Find proj.db
Andrew Bell andrew.bell.ia at gmail.com
Fri Mar 20 13:08:05 PDT 2020
On Fri, Mar 20, 2020 at 3:20 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Andrew,
> > - I created the items in this docker container by moving files from
> another
> > location to /usr/lib, /usr/share, etc.
> That's the likely issue. Running under strace will show you which paths
> are
> attempted.
Thanks,
Seems like I need to give the documentation a little love.
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200320/bd34dd7b/attachment.html>
More information about the PROJ mailing list
