[PROJ] Calling for 7.0.1 release
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Mar 24 09:05:00 PDT 2020
On 3/24/20 4:58 PM, Devrim Gündüz wrote:
> On Tue, 2020-03-24 at 14:12 +0100, Sebastiaan Couwenberg wrote:
>> Why don't you just add a patch to the RPM package for the time being, we
>> did that for the Debian package:
>> https://salsa.debian.org/debian-gis-team/proj/-/commit/8b7f0161d0786265362af5be6bedd2b001bad297
> I did, too:
> https://git.postgresql.org/gitweb/?p=pgrpms.git;a=blob;f=rpm/redhat/master/proj70/master/proj-7.0.0-sles12-pkgconfig.patch;h=33800266a9b8f7826a5ff6d499e12282ef8a45e7;hb=60ff67711307eb403fc1369aa5c92cccd86856fc
> But this requires aclocal-1.6 to build -- which is not available on RHEL 7.
Then I don't really see how a 7.0.1 release is going to help unless you
don't retool the sources.
You can also patch proj.pc to have the expected patch to not require
automake to generate it for you.
Seems easy enough to workaround on systems where the toolchain is too old.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200324/92376055/attachment-0001.sig>
More information about the PROJ mailing list
